585,599 active members*
3,483 visitors online*
    May 2006
    5
    Single line fonts
    Hello,
    I'm using the software solidedge to draw all my parts which I can import in my CAM system called SylvieXpert.
    The problem I have is with the engraving operation. I should design one part with a serial number but solidedge does not have single line fonts. Where can I find some to test ?
    I red a lot of articles about single line fonts but I never really got the right answer. The only way to solve it would be to work with CAM system which are handling that kind of problem like Alphacam.
    Thanks for your help
    Jan 2006
    2985
    something here might work.
    http://www.mr-clipart.com/int/anzeig...te=1&Anzahl=16
    google is your friend.
    Matt
    765
    Something else you could check out:
    www.ncplot.com
    There is a program on the site called StickFont that can be downloaded for free that will create g-code from a single stroke font.
    Regards,
    Scott
