Daily Maintenance of CNC Machine ROCTECH
Please keep the CNC machine continuous running time under 10 hours a day. If you use water cooling spindle, please ensure the cooling water clean and the water pump normal work, absolutely not appear water shortage phenomenon of the water cooling spindle, replacement of cooling water regularly, in order to prevent the water temperature is too high.
Attachment 254980
Every time after use the machine, should pay attention to clean up, be sure to clean up the dust on the table and the transmission system, on a regular basis (weekly) to lubricate the transmission system.(X.Y.Z axis)
Attachment 254982Attachment 254982
If long time not use the machine, should be regularly (weekly) lubricate and run empty, to ensure the flexibility of the transmission system.
Attachment 254984
Regular (according the use condition) cleaning the dust in the electrical box, check terminal screw if loosening, ensuring safe and reliable circuit is used.
Regular (according the use condition) check the machine parts screw loosening or not, etc
Vicky
