585,996 active members*
4,522 visitors online*
    Sep 2006
    Unhappy Takisawa TS-10 Indexing Problem
    I am having a problem with my Takisawa TS-10. When it attempts to index it the tool does not lock in to the proper postion. We have changed the encoder and checked the swtich. We have also removed the entire assembly attempting to look for broken teeth on the gears. All good. Any Suggestions?
    Sep 2006
    222
    Hydraulic valve solenoid worn ? Please try to move manually revolver, if it works you do have a limit swtch or relay problem.
    Sep 2006
    Unhappy Still Problems?
    :drowning:
    Ok We have changed out the Limit Switch and the Relays. They are all brand new and properly installed... Still having the problem with the Turrent not locking in to the correct tool position... Please help ASAP!
