585,712 active members*
4,068 visitors online*
Thread: Fusion 360
Page 1 of 2 12
Results 1 to 20 of 27
    Apr 2014
    14
    Fusion 360
    Does anyone have a subscription to fusion 360?Autodesk is coming out with Fusion 360 Ultimate on 10/08/2014 which will cost $1200 a year. but if you subscribe to standard before then ($300 a year) you get the ultimate version for as long as you keep your subscription going. But then I read something about Cloud points which cost a buck a point. I have no idea how they are used tho or if you even need them for doing CAD/AM in fusion 360. I work at a small machine shop using Master version 8 (not X8) for many years. We want to upgrade to Solidworks or Inventor with a plugin for CAD.Fusion 360 Ultimate gives you 3 axis machining and 3d cad. The website for Autodesk is hard to make sense of.Any feed back would be great thank you .
    Jun 2009
    195
    Re: Fusion 360
    try getting ahold of autodesk . but more than likely cloud services are included in the price . I will say fusion does not support milling of mesh models that are imported (from my use for organic models)
    other than that it is easy to use like solidworks and the cam part is very user friendly . I would download the demo and try it for yourself there are youtube videos to help get you started .
    tony
    Apr 2014
    14
    Re: Fusion 360
    Thank you for the reply Tony. I will find some time to get in touch with Autodesk before the 8th.We do not import anything at this time and have not worked with any mesh models so that should not be an issue.
    Thanks again.
    etg711
    Mar 2011
    79
    Re: Fusion 360
    You can direst any questions you have to [email protected]
    Apr 2014
    14
    Re: Fusion 360
    Thanks CamMan
    Jun 2009
    195
    Re: Fusion 360
    I will say if you post a question it gets replied too by people that know what they are doing and if you have a problem . I have had someone not working for autodesk mod a post for me on the weekend. It is a very friendly user base
    Tony
    Apr 2014
    14
    Re: Fusion 360
    This is a great forum. I have not made a lot of post but I learned a lot reading others posts.
    etg
    Feb 2009
    311
    Re: Fusion 360
    I subscribed a couple weeks ago and haven't heard anything about cloud points. I also haven't had a problem with machining imported models, although they weren't mesh models. I have machined from surface bodies so it may just require some converting to solids or fitting surfaces to your mesh model.
    $300/year for full CAD and 3D machining is too good to pass up.
    C|
    Apr 2014
    14
    Re: Fusion 360
    That's great to hear. I will be contacting Autodesk as soon as I can. Thank you cygnus x-1 for the info.
    Apr 2014
    14
    Re: Fusion 360
    I have had no answer from this e-mail address [email protected] is it possible there is no one there?
    Apr 2014
    14
    Re: Fusion 360
    I take that back. I just received a reply.
    Mar 2011
    8
    Re: Fusion 360
    Can you elaborate on their response concerning cloud points and Fusion360?
    Apr 2014
    14
    Re: Fusion 360
    Sure Spaceman,
    From my understanding there is no consumption of Cloud points with Fusion 360. I paid for a years subscription ($300) and have been screwing around with it for the past few days. So far it's pretty amazing .Oh yeah , Autodesk pushed back the release of the Ultimte version until 11/15/2014 so I believe the free upgrade is still available.
    Re: Fusion 360
    Yes, you can still get the $300/year for life deal through 11/15.
    Feb 2007
    711
    Re: Fusion 360
    Thanks for posting this, the free upgrade deal looks to good to pass up, and I am thinking really hard about subscribing.
    Feb 2007
    711
    Re: Fusion 360
    does anyone know what cloud points are, and what they may be used for?
    searching google only shows pages about point clouds.
    Apr 2014
    14
    Re: Fusion 360
    Cloud points are used for some of Autodesk's subscription services. I just signed up for Fusion 360 and was told I would not need them. One note is if you sign up monthly,quarterly or yearly to keep the upgrade you can't switch from one to the other after the 15th if you want to keep the upgrade. So I purchased the yearly subscription (best deal).
    Apr 2014
    14
    Re: Fusion 360
    Good news,
    Offer extended! Buy Fusion 360 today, and automatically get upgraded
    to Fusion 360 Ultimate (for life!) when it is released on December 13th!
    Ed
    Feb 2009
    311
    Re: Fusion 360
    Quote Originally Posted by etg711 View Post
    Good news,
    Ed
    I see where they extended the promotional offer, but I don't see where they pushed off the release of Ultimate until December?
    C|
    Re: Fusion 360
    Quote Originally Posted by cygnus x-1 View Post
    C|
    I see the opposite.
    Wait... Looking again, it looks like the date was changed back to 11/15. There was a December date an hour ago.
Page 1 of 2 12
  1. CNC Fusion
    By Scuba Steve in forum X3/SX3/G0619/G0463
    Last Post: 02-19-2013, 07:45 PM
  2. 7 x 12 cnc fusion
    By mbs5023 in forum Mini Lathe
    Last Post: 10-16-2011, 05:33 PM
  3. Another Q on the CR CNC Fusion Kit
    By rezcar in forum Benchtop Machines
    Last Post: 03-22-2010, 07:46 AM
  4. SX3 CNC with CNC fusion kit #1
    By adochoa in forum Benchtop Machines
    Last Post: 10-16-2009, 10:16 PM
  5. CNC Fusion
    By Memran in forum Benchtop Machines
    Last Post: 04-04-2007, 12:20 AM
