585,996 active members*
3,850 visitors online*
IndustryArena Forum > MetalWorking Machines > Hyundai Kia > Hyundai HiT-18s Siemens hard drive replacement
Results 1 to 16 of 16
    Nov 2014
    10
    Hello,
    The HiT-18s i have been operating has recently become inoperative due to a failed hard drive. I have done some searching and can't determined which hard disk drive will work, or where to find them. I am under the impression there is a limit on the space of the IDE hard drive required due to motherboard limitations. Is this true? Also are there other limitations on replacement drives needing to have identical firmware same model number and such? Thanks for reading.
    Jun 2004
    511
    Re: Hyundai HiT-18s Siemens hard drive replacement
    Pull out the original, and check Ebay for a match.
    Nov 2014
    10
    I ordered 1 from eBay used. But what arrived was only a pcb possibly the internals to a hdd. It needs to be an exact match on the drive?
    Nov 2014
    10
    What interface are these hard drives? I am unable to connect them to a pc for formatting. Also I've had the drives tested prior to trying them and I'm being told they are bad as well. Is there a different distributor that might have new or otherwise working drives? Possibly a cnc salvage company?
    Jun 2004
    511
    An exact match is most likely to work.Most CNC salvage shops are on Ebay. Worst case call Siemens.
    Nov 2014
    10
    Thanks for the reply. We've ordered a few hard drives, all in used condition. The tech has tried them all and determined they are bad as well. I was wondering how to connect them to a PC to give it a try at formatting myself. Siemens quoted something like $2500.
    Jun 2004
    511
    I have not worked on Siemens controls much, but on Hard drives on other CNCs I have had luck with the LOGICUBE products for making back up Hard drives.
    Jul 2004
    100
    I bought 20 drives on ebay and cloned them from the drive that came with my machine. It isn't difficult, but you need the right cables and software.
    Here is a link to the cables I bought
    USB 2 0 to IDE SATA 5 25 s ATA 2 5 3 5 Adapter Cable | eBay
    I don't recall the cloning package I used, but I can check at work tomorrow.
    I cloned all the drives and that may be the nut for you to crack. If you can't clone your existing drive, I can help you out.
    Regards, Ray
    ​"There is no such thing as a gun free zone."
    Ray Brandes, Ray-Vin.Com, PCB, FL 32408 USA
    Jul 2004
    100
    The drive you need is a 2.5" IDE drive.
    Either physical or solid state.
    I am still trying to get the name of that cloning software that worked great.
    Regards, Ray
    Jul 2004
    100
    Quote Originally Posted by RBrandes View Post
    Regards, Ray
    The software I used is R-Drive Image
    Drive Image and Hard Disk Backup Software
    Regards, Ray
    Nov 2014
    10
    Turns out i was working off the wrong information the hard drive was not the issue. It was the keyboard interface.
    Sep 2008
    100
    I also have a lathe HIT 18s with Siem840C but has no hard disk drive, anyone can sell me a clone of the hard disk drive
    TKS
    Feb 2015
    5
    Hi .
    can someone provide me file anw_prog for hit18s?
    thanks
    Feb 2015
    5
    Hi .
    thanks
    Jan 2019
    Quote Originally Posted by saxon1978 View Post
    Hi .
    thanks
    Did you find the answer on your hard drive replacement question? I just sent my board to Siemens, they replaced the hard drive with a new flash drive and installed the software on it. Besides having to adjust the parameters all again, it seems to be a good fix
    Mar 2020
    How much did Siemens charge you?
