I'm trying drip feed to a Lagunamatic 3 axis mill with a desktop PC. I have the serial connection hooked up. Mastercam is sending the programs, but the controller says it doesn't have communication. It's a Dynapath controller. Any tips?
phoodieman
phoodieman
First thing I would check is to be sure your comm ports are set the same on both cnc and pc
Is the controller set in the rs232c mode?
Cable problem ?
Please check: cadem.com
Cable is good. Pinout is right. The controller is ready. I think it might be settings in the PC, but everything seems to be right. I'm stuck.....
Phoodieman
Is it a Dynapath 20 controller?
Do you load your programs using this desktop?
