585,712 active members*
4,357 visitors online*
    Sep 2006
    ABB S3 controller
    I have a ABB old robot IRB6000 with S3 controller.
    Now I want to setup connection from PC to S3 controller's serial port, using
    Hyperterminal.
    Does anyone has this experience and can help me?
    Jun 2010
    I know that I am reopening a really really old thread, but how about using a controller like like this http://www.emx.net.au/super4usbrelay.htm to simulate pressing the buttons on the S3 controller. I do not have any experience with this so it is just a wild guess. I have seen other posts about similar things, and this could solve their issues as well.
    Jan 2010
    8
    ABB S3 flppy drive update
    Hi ABB fans, here a new gadget for your ABB S3 Robots.
    FlexiDriveMV-SD - Floppy Drive Update to SD card.
    This is a direct replacement for the floppy drive unit.
    You remove the actual 3.5” floppy drive, connect the FlexiDrive and that’s all.
    You will not use floppy disks any more.
    You will use a standard SD memory card. You can storage up 2500 floppies in a single SD card.
    Also for all ABB from S4 to S4c+, old KUKA's, Kawasaki's, FANUC's, or any industrial machine!
    FlexiDriveMV – Robot ABB S3
    Sep 2013
    9
    Re: ABB S3 controller
    Simple floppy emulator:
    Attachment 229598
    Floppy emulator SD card drive-Floppy emuDrive
    Sd card FAT16 and FAT32.
    WiFI SD card support.
    No outward protrusions such as USB, all covers over floppy device can be still closed after floppy emulator installation.
    Jan 2010
    8
    Replace your floppy drive on your your ABB S3 Robots now!
    Robots ABB S3 Floppy Drive | FlexiDrive - Floppy Drive Emulator
    Now powered by WiFi SD Card !!
  1. Mitsubushi controller , meldas 60 , controller M64
    By rintomeledath in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 02-05-2014, 07:05 AM
  2. Central PID Controller vs. PIV Controller in each Servo Amp
    By Bronx68 in forum CNC Machine Related Electronics
    Last Post: 11-20-2013, 05:33 PM
  3. Pacer old controller card to new controller box??
    By ecotrails in forum Controller & Computer Solutions
    Last Post: 09-16-2010, 09:17 PM
  4. Replies: 4
    Last Post: 11-07-2009, 06:03 AM
  5. DeskCNC 2nd. gen controller AND HobbyCNC Pro Controller
    By maycom in forum DeskCNC Controller Board
    Last Post: 06-02-2007, 07:33 PM
