Number |
Description |
Parameter |
1 |
X,Y,Z Working Area |
1500x3000x300mm |
2 |
Table Size |
1550×3050mm |
3 |
X,Y,Z Traveling Positioning Accuracy |
±0.03/300mm |
4 |
X,Y,Z Repositioning Accuracy |
±0.03mm |
5 |
Table Surface |
Vacuum and T-slot Combined (Option: T-slot table) |
6 |
Frame |
Welded structure |
7 |
X, Y Structure |
Rack and Pinion Drive, SKF Rail Linear Bearings |
8 |
Z Structure |
Hiwin Rail Linear Bearings and Ball Screw |
9 |
Max. Power Consumption |
(Without Spindle) 4.5kw |
10 |
Max. Rapid Travel Rate |
45000mm/min |
11 |
Max. Working Speed |
30000mm/min |
12 |
Spindle Power |
9kw |
13 |
Spindle Speed |
0-24000RPM |
14 |
Drive Motors |
Yaskawa servo |
15 |
Working Voltage |
AC 220V/50/60Hz,3PH |
16 |
Command Language |
G Code |
17 |
Operating System |
Syntec Control System |
18 |
Computer Interface |
Ethernet |
19 |
Flash Memory |
256M with CF card |
20 |
Collet |
ER32 |
21 |
X,Y Resolution |
<0.03mm |
22 |
Software Compatibility |
Becam software , Artcam software |
23 |
Running Environment Temperature |
0 - 45 Centigrade |
24 |
Relative Humidity |
30% - 75% |
25 |
Packing Size |
3840*2210*2200 mm |
26 |
N.W. |
2000KG |
27 |
G.W. |
2300KG |
28 |
options |
Dust Collector |
Rotary System |
Mist-cooling System
