585,555 active members*
3,464 visitors online*
    Aug 2007
    32
    HSK Tooling Wont release
    Hi Guys,
    I have a Fimec ES929 HSK 63 spindle with less than 100 hours use which I allowed to bottom out on some MDF for a couple of minutes.
    When I removed the slightly discoloured tool holder and cleaned it up there was a bit of greasy residue in the bottom the tool holder cavity which I hadn't noticed before
    I tried to clean out and cool the lower end of the spindle- yeah I know now a dumb- to ensure the bearings were OK.
    Since then I have inserted another tool only to have it seize up in the Spindle nose.
    So far not wanting to damage anything with the knochrometer I have dismantled as much of spindle as I can but still can't dislodge the tool holder
    Any suggestions would be greatly appreciated in an effort to remove the Tool holder and prevent any furthe issues .
    Pete
    Mar 2008
    683
    Re: HSK Tooling Wont release
    This happened to mine. Wood pitch built up. The solution was the knockulator. I held in the tool change button and GENTLY tapped the holder. It popped out with a vengence. Put a pad or some other way to catch it.
  1. Tool wont release
    By pbd1971 in forum Haas Mills
    Last Post: 05-29-2012, 08:24 AM
  2. Replies: 4
    Last Post: 05-07-2012, 12:54 PM
  3. vf4 wont release tool holder
    By panaceabea in forum Haas Mills
    Last Post: 08-25-2009, 11:02 PM
  4. New release?
    By harley4ever in forum Dolphin CAD/CAM
    Last Post: 03-06-2009, 03:50 AM
  5. New release of CeNeCe PRO 1.07
    By DaniSaez in forum CNC Wire Foam Cutter Machines
    Last Post: 11-20-2006, 11:49 PM
