585,978 active members*
4,189 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > chuck pressure alarm OKUMA
    Sep 2010
    80
    Okuma LB -35ii M, OSP 7000L. My question is when ever i switch from manual to AUTO,I get a Pressure alarm and light. Machine shuts down. Any suggestions thanks in advance
    Mar 2009
    1982
    Re: chuck pressure alarm OKUMA
    prepare for diagnostic: make sure, the machine makes no move while diagnosing. disconnect the pressure signal from the point as close to the sensor as possible. Arrange the signal "no pressure alarm" to the control at the point as close to the disconnected point as possible.
    diagnostics: repeat the fault conditions: switch from manual to auto. locate the place, where the signals are interfering.
    Apr 2009
    1262
    When you say "shuts down" do you mean power goes off? If yes, check for auto shutdown switch being on. If not, do you get any alarm number or do you have any external equipment connected ?
    Best regards,
    Sep 2010
    80
    Thanks for the reply.....Apparently the operator was unknowingly playing with some timers and set one to zero. So it never got a chance to detect pressure....He forgot to mention that lol
  1. Leblond / Fanuc OM Lube Pressure No 2050 Oil Pressure Alarm
    By alcarinc in forum Uncategorised MetalWorking Machines
    Last Post: 01-13-2015, 03:02 AM
  2. Replies: 31
    Last Post: 10-11-2011, 03:33 PM
  3. Replies: 2
    Last Post: 09-01-2011, 06:16 PM
  4. Chuck high low pressure
    By MCR-B II in forum Okuma
    Last Post: 07-23-2011, 07:22 PM
  5. Replies: 4
    Last Post: 06-12-2009, 09:15 PM
