585,906 active members*
3,676 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > slaved motor runs in opposite direction of master on gantry machine.
    Mar 2014
    6
    I have built a Joes Evo machine with some minor modifications, using Joes plates. In Mach 3 I have the Left side as the Y axis and the opposite side, as the A (slave) axis. If just the Y is engaged, it works fine, although not as stable as if the two were running in concert. In a similar vein, the z axis seems to be going up when it should be going down. (running the open sign path from vcarve) Everything that has been a major crisis initially so far has turned out to be a simple fix, I have read and re-read the Mach 3 manual and all of the other materials I have, and this one has me puzzled. I am sure I am missing something.
    I have Mach 3, Joes Plates, velox 10:1 z slide with drop plate, CNCRP nema 23 kit, gecko 540. I haven't put alot of time into the ESS from Warp9, figured I would incorporate that later, as things seem to be progressing nicely without it.
    Thanks, John
    Jun 2006
    198
    Re: slaved motor runs in opposite direction of master on gantry machine.
    In Mach3, you setup your ports and pins. In your motor pins setup, reverse your directions on the slave motor and your z axis motor.
    Motor Outputs and then Dir Low Active. click it green, then the rotation is reversed on the motor.
    Mar 2014
    6
    That worked, thank you!
    Jun 2006
    198
    Ur welcome.
  1. Mach3 is moving in the opposite direction
    By maly-miller in forum Mach Mill
    Last Post: 03-04-2014, 03:00 PM
  2. Making a slaved X Axis gantry perfectly square
    By TheBulk in forum DIY CNC Router Table Machines
    Last Post: 09-08-2011, 05:58 AM
  3. Phase converter/lathe runs in one direction or the other
    By eScott in forum Phase Converters
    Last Post: 03-20-2010, 11:50 PM
  4. x axis only runs in one direction PLEASE HELP
    By m8kingit in forum DIY CNC Router Table Machines
    Last Post: 10-25-2009, 05:53 PM
  5. MOTOR DIRECTION CHANGE, RUNS RUFF.
    By Inivator in forum Mach Software (ArtSoft software)
    Last Post: 07-31-2008, 07:19 PM
