585,712 active members*
4,489 visitors online*
IndustryArena Forum > CAM Software > Visual Mill > Jigsaw pieces not fitting
    Feb 2005
    53
    Question Jigsaw pieces not fitting
    I'll come back to this one.
    Made some mistakes
    Prboz
    Feb 2005
    53
    Re: Jigsaw pieces not fitting
    Ok So I've had a play trying to get the parts to match but for some reason they seem to be the thickness of the cutter (1.4mm) out on the radius only.
    The distance between the maiting flat sections seem to be ok.
    I'm a bit lost as to why this is happening.
    Any Ideas
    Apr 2004
    5734
    It sounds like you're not offsetting for the radius of your cutter. There's a screen in the Profile dialog that asks you if you want to cut on the line, inside it, or outside it; you probably want to cut outside.
    Andrew Werby
    Website
    Feb 2005
    53
    I have set the cutter compensation for a 1.4mm cutter. It is strange as it is only the radius and the inside lines which are an issue. The parts back to back ok, so the width is not a problem
    The radius is incorrect and the taper is out aswell.
    Will keep trying things and see what happens
  1. Custom Jigsaw Puzzle
    By P.Passuello in forum Videos
    Last Post: 08-20-2014, 10:56 AM
  2. cutting jigsaw puzzles
    By xhorton in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-13-2012, 04:46 PM
  3. jigsaw puzzle making machine
    By lisacutcnccam in forum News Announcements
    Last Post: 11-23-2012, 08:47 AM
  4. Jigsaw delight
    By cncadmin in forum EnRoute
    Last Post: 04-27-2012, 06:00 AM
  5. CNC router or jigsaw
    By bbsmfg in forum DIY CNC Router Table Machines
    Last Post: 09-02-2006, 02:18 AM
