585,992 active members*
5,238 visitors online*
IndustryArena Forum > MetalWorking Machines > Bridgeport Machines > Bridgeport / Hardinge Mills > Machine Parameters Bridgeport Interact 1 MK2 TNC2500
    Nov 2014
    Hello Everyone.
    Looking for a machine parameters. Machine lost all parameters because low battery level.
    Bridgeport Interact 1 MK2 Heidenhain TNC2500
    NC Software 280 500 10
    PLC Software 250 144 10
    Thanks for any help.
    Nov 2014
    I typed parameters from the same machine, but without the 4 axis.
    I get an error when you try to reference dimensions
    "gross positioning error Z Click image for larger version.
    Sep 2003
    72
    Re: Machine Parameters Bridgeport Interact 1 MK2 TNC2500
    I have a parameter list for a Bridgeport Interact 1 MK2 TNC 2500C Year 1994. If you want I can send you a copy. Machine is with three axis. Or else contact Bridgeport and they should be able to send you a copy of the parameters.
