Chinese Laser Cutter - Strange Engraving Issues
Hi there, bit of a newbie to the laser cutter forums so please excuse my lack of knowledge. Anyway here goes...
I've had my Chinese machine for about 3 months now and have been really impressed with it, came fully working right out of the box and have had no issues, until now.
The problem is probably best illustrated through the photos, but basically the engraving is behaving pretty erratically, with power from the laser being fired irregularly - for instance if I was to engrave a square into a piece of wood and then cut it half on a saw, the engraving profile would be different to, let's say if I engrave another square but this time it has a circle in the middle. The engraving tends to start off really weak in both circumstances, and improve if the laser has to 'jump' in order to clear some artwork in the middle of the square.
It used to be completely fine, and engrave all the space around the artwork within the square at the same depth. I really don't get what's going on and I'm desperate to get it fixed as work is piling up!
The laser has had some pretty heavy usage, sometimes engraving 8 hours with intervals per day, but I'm sure it hasn't reached it's 2500hr max usage. However, it also won't cut through a piece of 3mm hardboard anymore, even on a max power / low speed setting.
The pics attached show two planks cut with the same file stored on the laser cutter (top one cut when I got the laser, bottom one cut yesterday) Note the 'sloping' towards to the top of the letter which improves as soon as the laser has to jump to clear the letterform.
Anyway thanks for reading and I really appreciate any help or feedback on this.
Tom
Chinese Laser Cutter / Engraver 300x500 | RD Works | Bofa IDOracle Extraction
