585,573 active members*
3,584 visitors online*
Results 1 to 10 of 10
    Nov 2014
    4
    AWC708C Lite network problem
    Hi. I have just swapped from a Leetro laser controller to an AWC708C Lite. The swap was fairly easy, but now i cannot connect my computer to the new controller. I am using a LAN connection cable, but no matter what i do or the IP address i use, the computer still won't connect to the controller. Any help or ideas will be greatly appreciated. I am fresh out of ideas. I am using the IP address that is in the controller, 192.168.8.8
    Mar 2005
    159
    Re: AWC708C Lite network problem
    More information is needed.
    What is your skill with networking?
    I would start with the basics:
    Are you running Windows or Linux? Can you pull up the IP of your computer?
    What network is your computer on? Same 192.168.8.XXX ??
    What is your subnet mask? 255.255.255.0?
    Can you ping the 192.168.8.8 from your computer?
    What do you mean by connect? Should the AWC708C be visible on the network or do you need some type of driver / software to talk to it?
    James
    Nov 2014
    4
    Hi James,
    Thank you for your reply. I am new to networking so please be patient. I am running Windows XP. The computer has a totally different IP address. I have tried to ping the laser IP but it does not connect. 4 tries, no success. Subnet mask i have no idea. Apparently it does not require a driver. The AWC708C should be visible on the network,
    Thanks, Bob
    Mar 2005
    159
    Hi Bob,
    It sounds like the root of your problem is that the two machines (computer and controller) are on different subnets. No problem.
    1. Find what network the computer is on.
    2. Change the IP in the controller to be on the same network.
    Windows XP. I love XP but it's been a while since I had to administer an XP machine and my memory is not what is used to be but I'll give it a try ))
    Go to control panel (start menu > Control Panel)
    Find "Network and Internet Connections" and double click it.
    Find "Network Connections" and double click it. This will list the adapters you have on that machine.
    One should be labeled "Local Area Connection" and have the word "Connected" somewhere in the text. Double click that.
    That should bring up a small window labled "Local Area Connection Status". Click on the tab labled "Support" and you should see your IP information.
    Take note of the "IP Address", "Subnet Mask" and "Gateway".
    Go to your AWC708C and set the IP to match your computer except for the IP address. Change it to something different.
    For example if your computer IP is 192.168.0.23, change the AWC708 to 192.168.0.200 (or some number near that). Make the subnet mask and gateway match your computer.
    I assume you have an instruction manual with the AWC708 and it explains how to change the Network Settings??
    James
    Nov 2014
    4
    Thanks James. I'm off to bed now so i will check and change in the morning. I really do appreciate your time and effort to explain it to me. I'll let you know how it goes
    Thanks, Bob
    Nov 2014
    4
    Hi James,
    Managed to get it all worked out with your invaluable help. It turned out that the original computer i was using would not show the LAN connection for the computer in "Network Connections". Changed to another computer and applied the settings as you described, and it all worked. I am over the moon now. All is working very well. Thank you again for your assistance
    Thanks, Bob
    May 2015
    AWC708C Lite It works well and in line with the win7
    May 2015
    53
    yeah .. well ... including the win8 / win 7
    Mar 2017
    4
    Hello good afternoon
    I have a problem with my awc 708 c lite, when I want to give the parameters, it says that I must press stop long. But I do and nothing happens stays in that same menu ... someone who can help me please ??
    Manufacturer Parameters Settings
    Press 【Stop】button and not loose it.Then input numbers【 shift 】to enter Manufacturer Parameters Settings interface.
    thanks my friend
    Aydin
  1. Casmate Lite
    By jknoflicek in forum Engraving Machines
    Last Post: 09-27-2012, 01:31 PM
  2. Problem with NCnet Lite....
    By gearsoup in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 06-24-2011, 06:29 PM
  3. ncnet lite
    By krustykrab in forum DNC Problems and Solutions
    Last Post: 02-10-2010, 08:15 AM
  4. Problem with spindle using motenc-lite board
    By jatchan in forum LinuxCNC (formerly EMC2)
    Last Post: 03-23-2009, 08:41 PM
  5. Problem with files on Network
    By JMFabrications in forum Mastercam
    Last Post: 02-04-2008, 08:13 PM
