Im new here to the forums and im looking for a cnc mill solution. The stock i will be milling is approx, 2in high X 2in wide X 11in long. It will be both aluminum and steel.
What is a good solution for a relatively cheap small cnc mill that will handle this material easily. Ive looked into the Taig mills, but theyre lowest spindle speed is 1000 rpm only allowing I guess a 1/4" cutter which will take all day.
Thanks for any suggestions
