OK it is driving me crazy... my system is driving me nuts, I had a computer die on me ended up switching to win 7, pro. I finally found my 17.2 disks and got them loaded. recently started to optimize an old tool path, same geometry, now I cant get smartpath to turn off. I can't get it to stop inserting g8 and g9 and now the program reads the first path correctly, except for all the inserted g11 codes and undesired exact stops then on the second path it inserts a g8 and g9, which it doesn't read, then instead of the ramp entrance it goes straight to the g3 which it cuts in the wrong place and it stops.
I have put SMARTPATH: OFF in the tool path, as well as manually entering it , I have tried to save the smartpath ppp file but every time I do I get a system error path not found. I have looked through the documentation and cant find the path it looks for. I have tried booting it from the as3000 file and the cnc file to see if that made a difference, same result
amy body got any clues?
