586,013 active members*
3,807 visitors online*
    May 2010
    7
    help with mach3
    Hi I am new to this forum. i have chinese cnc model 3040
    I wonder if anyone can help me, I have problems with mach3 I had it in windows xp and it worked fine but then did not recognize the whole design just part of it, I thought it was for the OS update my pc, install windows7 32 bits, installs fine, the axes move on the screen but not on the machine no. Run parallel input register and the entry of overwriting memory, there all good but still does not move the axes in the machine, run the Drive test pc and the machine restarts and runs the pc controls the machine, but the load the design does not come out completely. That's my problem can someone please help me with this, thank you very much.
    Dec 2012
    Re: help with mach3
    Just a thought. Did you remember to set up mach3 pins and ports after? Speed of motors, and all the related entries?
    Feb 2011
    212
    Re: help with mach3
    I had thus problem when I switched computers . If I remember er correctly I did not have my Mach completely installed. Be sure it is completely installed and you load your xml file I think that's what it was called lol. Be sure the drivers are installed
    Hope that helps
  1. To mach3 or not mach3, opinions requested
    By KenCameron in forum HURCO
    Last Post: 10-07-2014, 10:05 PM
  2. CAM for Mach3
    By CricutDude in forum Uncategorised CAM Discussion
    Last Post: 04-06-2011, 08:24 PM
  3. Differences Between Mach3 Mill and Mach3 Plasma?
    By cjjonesarmory in forum Mach Plasma / Laser
    Last Post: 11-18-2010, 04:12 PM
  4. Using Mach3 with Reprap extruderUsing Mach3 with Reprap extruder
    By router101 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 11-03-2010, 10:46 PM
  5. Mach3 w
    By fkz in forum Machines running Mach Software
    Last Post: 03-11-2010, 09:31 AM
