A book about the plan to build a cabinet for a router machine. Raychar CNC DIY router cabinet Plans milling machine. You can search it in the famous on line auction web.
It recorded the whole process of building a cabinet for a popular CNC router milling machine; High Z S400 from Heiz. This machine is of dimensions 700/520/550mm as quoted by manufacturer's manual. The built cabinet is of outer dimension approximately 860/620/1460mm. The cabinet provides a user-friendly vertical-sliding shield enclosure. As many people use router to cut PCB or plastic material. An air suctioning system which included a brush hood was built for suctioning these light debris. For wet cutting, as some people may do, router machine is used to cut alumimium block in making small temporary injection molds, so it needs to have a coolant system and filtering tank which are for supply of coolant, filtering and storing the cut out material. This also included in this cabinet. Electronic circuits for controlling the power levels of these two systems were also installed and well described in the book.For other conventional desktop cnc milling or router machines, adjustments in mechanical dimensions were needed. The book listed the procedures in the determination of some critical dimensions. There are totally 110 pages of which 23 pages of drawings.
