Originally Posted by
jonstap
Great reply, thanks for the info, I have checked and the problem was the X-Axis pulley (runs on timing belts and I gather now are pulleys, thought they were called sprockets hah). Cuts proper shapes now.
My problem now being, although all is working, i calibrated the steps per mm and the machine cuts small when running Aspire generated code in Mach3. Then I tried calibrating using Mach3s auto calibration over 900mm. Set these but again G code cuts small (only a mm or 2, but still smaller than I wanted).
I cut a 29mm circle and it came out 27.5mm cutting on inside profile with 6mm cutter. I will get some experimenting done over the next few days to see if I can fix it.
Thanks for all the advice
Jon
