585,991 active members*
4,725 visitors online*
IndustryArena Forum > CAD Software > Solidworks > Modelling spring tangs in several planes - a bit lost!
Results 1 to 6 of 6
    673
    Hi - Still trying to get my head around lofting to create ends of a coil spring that end in two different planes. The bottom (start) end needs to sharply turn 90 degrees and the top end needs to bend in to the centerline and down. I'm having trouble trying to visualize it. I created the basic spring, a start and end circles along with some guide curves, but can't quite seem to get it. Can you "guide me" so to speak The picture shows what I'm trying to do and my part is attached. Any help is greatly appreciated.
    Attached Files Attached Files
    Apr 2012
    141
    Re: Modelling spring tangs in several planes - a bit lost!
    all you need to do is put the path to the center of the diameter of the spring ....
    i think ...
    673
    Thanks for the tip. So you can't do movements in 2 planes at once? I was looking to be able to go towards the center of the spring, then down some, then out... that's 3 separate sweeps then?
    Thanks!
    Apr 2012
    141
    Yea sure you can .... Sketch in 3d
    Do a spline curve in 3d sketch mode, it's a bit daunting at first to get the spline on the correct planes , but with a little practice :-)
    Jun 2008
    562
    Quote Originally Posted by Spinnetti View Post
    Thanks!
    Take a look at the files, one is your spring using you guide curves, the other is one I did previously that will get you headed in the right direction. You should work from the centerline of the spring and give the guide curve and center of circle a pierce point relationship. Can't do 2 planes at once
    Mike
    673
    Thanks Guys! I think I'm starting to catch on
  1. Modelling A Pushchair
    By Raz11 in forum Solidworks
    Last Post: 01-23-2012, 06:41 PM
  2. Looking for a 3D Modelling Package
    By pbd1971 in forum Uncategorised CAD Discussion
    Last Post: 10-05-2011, 05:35 PM
  3. Modelling & linetypes
    By CNC-Hammer in forum Autodesk
    Last Post: 03-31-2009, 08:17 AM
  4. PRS modelling
    By betterfly in forum Musical Instrument Design and Construction
    Last Post: 08-13-2008, 10:00 PM
  5. Learning 3D modelling
    By randyf1965 in forum Uncategorised CAD Discussion
    Last Post: 01-12-2006, 01:27 PM
