585,715 active members*
4,185 visitors online*
IndustryArena Forum > MetalWorking Machines > Cincinnati CNC > Arrow 1000 only one spindle drive key?
Results 1 to 6 of 6
    Feb 2012
    24
    My company just got a used year 2000ish Cincinnati Arrow 1000 VMC with the 2100 control. In th process of getting it up and running, and one thing that I cant understand is why there is only one spindle drive key? There is two cutouts for drive keys but only one of them has a key and the other doesn't even have a tapped hole for adding one. It looks just like this one in the link below. My question is why they would make a machine that only has one drive key. Anyone know?
    Cincinnati Saber Arrow 500 CAT40 Spindle | eBay
    Apr 2004
    353
    This is how they were all made. Make sure when you load tools in the carrousel that the dimple on the side of the toolholder is opposite the drive key on the spindle.
    Under normal conditions it's the taper fit of the tool and the spindle that drives the tool
    Feb 2012
    24
    Re: Arrow 1000 only one spindle drive key?
    Wouldn't this be bad for any kind of heavy milling? What was the idea behind having only one key?
    Dec 2006
    584
    If you look at the way the machine changes tools, the extra drive key would hit the inside of the tool drum. The arrow machine does not have the power at the spindle to require two keys. It is only a 40 taper, a 50 or 45 taper spindle needs two keys because of more H.P. I agree that the spindle would seem to be better balanced with two keys, especially at higher speeds.
    Mike cncmachineservices (dot) com
    15362
    MillingMan
    Most machines that use one key, use BT tool holders, so make sure it does uses Cat tooling, it could well be a BT spindle
    Mactec54
    Dec 2006
    584
    This machine should have the standard 40 taper Cat tooling. Cinci did not make any of the Arrow 1000 machines with BT tooling that I have ever seen in the field.
  1. arrow 1000 spindle won't align
    By davesnd in forum Cincinnati CNC
    Last Post: 06-02-2013, 12:46 AM
  2. spindle drive fault Arrow 500
    By scudzuki in forum Cincinnati CNC
    Last Post: 11-12-2010, 02:36 PM
  3. Arrow 1000 spindle trouble
    By raygun in forum Cincinnati CNC
    Last Post: 03-03-2009, 04:32 AM
  4. with a Dover air Spindle, DMM-1000 drive connections
    By DiamondGirl in forum Servo Motors / Drives
    Last Post: 02-19-2008, 02:56 AM
  5. Cincinnati Arrow 500 Spindle Drive wiring
    By professor in forum CNC Machining Centers
    Last Post: 11-24-2007, 02:47 AM
