I don't think I ever shared my 1st cut with the machine before I started the rewire.
The surface finish on the edges left a little to be desired, largely due in part with using an 1/8in downcutting bit (my mistake). You can see the large chips from when I failed to double check my DOC and it did a full DOC which caused the tool to pull out a bit driving it further into the part. I saw what was happening and figured it was a $3 EM and let it run. It did great until it it the 1st arc and snapped.
The engraving was cut with an 1/8in 60 degree vBit from Drillman1 on eBay. I use his bits a lot on my router.
I used it to stamp the AF logo into some leather. I was pretty impressed with the results.
