585,883 active members*
5,909 visitors online*
    Mar 2013
    32
    Y AXIS WRONG DIRECTION
    Any HAAS tech,
    I tried to home first thing in the morning and the Y axis started moving the wrong way, any clues?
    Jul 2005
    12177
    Re: Y AXIS WRONG DIRECTION
    Yes, the limit switch has malfunctioned. Depending on the age of the machine it is either a mechanical switch or an inductive sensor. If it is a pre-2005 machine (or somewhere around that date) it will be a mechancial switch which has just hung up in the activated position. On a more recent machine very often a chip will get stuck on the sensor keeping it activated. Either way you are going to have to take off the covers and find the switch/sensor.
    Feb 2010
    1184
    Quote Originally Posted by Geof View Post
    Yep, what he said!!
    Mar 2013
    32
    thanks for the help. I did locate what seems to be a switch and since it is not moving I am assuming it is inductive. and it glows (pilot light) without anything around.
  1. Help! x-axis is alining in the wrong direction
    By jasonaldrich in forum Cincinnati CNC
    Last Post: 07-31-2014, 04:23 AM
  2. Need Help! Y-axis wrong direction
    By ponte in forum Redsail Laser
    Last Post: 08-10-2013, 03:07 AM
  3. Z-axis only turns in ONE direction, anyone know what might be wrong?
    By effimos in forum DIY CNC Router Table Machines
    Last Post: 03-15-2012, 01:20 PM
  4. Z axis going in wrong direction
    By erkiwi in forum CNC Machine Related Electronics
    Last Post: 01-20-2010, 11:43 AM
  5. integrex 200 II SY b axis wrong direction
    By smile in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 06-07-2006, 05:09 AM
