585,996 active members*
4,510 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > Everything was working fine, then stopped (G540 and SS-USB)
    Aug 2013
    14
    I've been working on this plasma CNC for the better part of a year (off and on).
    Recently I was having problems slaving my A axis to another axis. However, I could slave my Z axis to X or Y. I sent the G540 back to Gecko and they said everything checked fine. Never really resolved that problem.
    Well, I was willing to work with that. Then the night came for me to install my steppers onto my gantry. I was super excited.
    Quick note: I was running some smaller steppers (3A, 3.5mH) but they had a 1/4" shaft but discovered CNCRouterparts 3/8" shaft steppers so I swapped to those.
    I installed the motors onto the gantry, connected the wires, and nothing. So, I removed the motors to test them somewhere else besides in a freezing garage.
    I swapped back to the small motors and got motion. ALL paramters never changed. I swapped back to CNCRouterparts motors and finally got them going (again, NEVER changed any of the configurations. I figured it was a loose connection).
    Well, that was two nights ago. Tonight I went to fire it back up and test it one more time before I threw it back on the gantry. I NEVER touched my setup since I last had it going two nights ago. Everything turns on but when I open Mach3 to try and jog the motors, nothing. I test run a file and the program just sits on a line of code.
    Everything I've done so far that didn't work:
    Exchanged back to the smaller motors
    Switch pins in the P&P configuration as well as tried different configs
    Uninstalled/Reinstalled Mach3, updated SS-USB drivers to 2.8.24/28/30 respectively, installed v17f/17ef respectively.
    No response. I know when I used to change parameters and restart the program, I could hear the motors jitter from the changes. Now they just sit there unresponsive. They have holding torque and will fault if I do something like remove a configured motor. No faults on the Gecko and SS. Diagnostics in Mach3 check fine.
    Any ideas? I'm getting desperate to finally get this plasma table going.
    Aug 2013
    14
    Re: Everything was working fine, then stopped (G540 and SS-USB)
    Good Gosh. I had one little hunch after I made my post.
    When I was swapping between motors two days ago and couldn't explain why the new steppers suddenly worked...
    Well, I swapped one of my ribbon cables that connects from the SS to the Gecko ( guess I could've just config'd from port 2). Works now. I must have a disconnect in my other one.
    False alarm.
    Dec 2007
    2134
    Good to hear all's well that ends well!
    As annoying as those "doh" moments are, it's still a relief to know nothings actually wrong.
    cheers, Ian
    It's rumoured that everytime someone buys a TB6560 based board, an engineer cries!
  1. G540 stopped working
    By enricodina in forum Gecko Drives
    Last Post: 10-22-2014, 10:01 AM
  2. G540 has stopped working after 6 months
    By cnc3678 in forum Gecko Drives
    Last Post: 06-03-2013, 11:16 AM
  3. G540 Outputs stopped working
    By rk396 in forum Gecko Drives
    Last Post: 09-25-2011, 07:53 AM
  4. SX3 Stopped Working
    By mikemill in forum Syil Products
    Last Post: 01-09-2009, 04:54 PM
  5. Bandit stopped working
    By Chris64 in forum MetalWork Discussion
    Last Post: 12-18-2006, 02:02 AM
