Whatever SteelTailor portable CNC cutting machine or Torchmate cnc plasma cutting machine come to your mind when you're looking for plasma cutting machine manufacturers, you have to firstly consider the following essential requirements to your business.
1. The materials you need to cut with plasma cutting machine.
For most small cnc plasma cutting machines, mild steel, stainless steel and other metals can be cut by plasma cutting or flame cutting mode.
2. The thickness of the material you prefer cut with plasma cutting machine.
Take SteelTailor Smart series industrial plasma cutting machine as an example, flame mode can achieve 5-150mm thickness.
3. The largest size of your raw sheet metal cut with plasma cutting mahcine.
Since SteelTailor Smart series small portable table CNC cutter and Torchmate Growth series table CNC cutting machine are table-sized small cnc plasma cutting machine, the size of raw sheet metal can meet general requirements, rectangle or square, conventional graphics or special-shaped.
4. The cutting quality you require with plasma cutting machine
The most obvious one to test cutting quality is the cutting surface effect. In other words, the smooth, clear and dross-free cutting samples made by SteelTailor or Torchmate industrial cnc plasma cutting machine manufacturers can be defined as high qualified.
Reference:
Smart III portable table plasma flame cutting machine - - SteelTailor offers portable CNC cutting machines,portable table plasma cutting machine,CNC plasma and flame cutting machine,cnc plasma cutters
http://torchmate.com/products/growth...wth-series-4x4
