585,997 active members*
5,022 visitors online*
    Apr 2004
    16
    VSD-E dual DC, home switches?
    Hi!
    Is there a way to wire home switches when running one VSD-E as dual DC (X and Y axis)?
    I have the VSDEPI breakout board.
    Pär
    Nov 2005
    12
    Re: VSD-E dual DC, home switches?
    Quote Originally Posted by Pairair View Post
    Hi!
    Pär
    Reading through the DualDc docs, i would guess that success comes down to your control software on the driving computer. If your software supports all home switches on one input pin.
    No two axis can trip the home switch circuit a the same time. Auto homing function of the VSD-E throught firmware doesn't seem to be supported either. Logicaly homing one axis at a time will have to happen on the control software on your PC.
    Home connects to Encoder pin 1 on the VSD-E Dual and then to ground. Home signal is passed to VSD-E Dual CMD connector pin 12, but no mention is made of which pin this is routed to on the VSDEPI. Could try loading a port monitor in Linuxcnc and see which pins toggle when you manualy trip the home switchs.
    Hope that helps.
  1. Home and Limit Switches, Dual Color and Panel indication!
    By Falcon69 in forum News Announcements
    Last Post: 12-11-2013, 09:19 PM
  2. Replies: 3
    Last Post: 11-05-2013, 02:54 AM
  3. Gantry with dual home switches
    By elogicca in forum LinuxCNC (formerly EMC2)
    Last Post: 12-18-2007, 04:15 AM
  4. The relationship of limit switches to home switches.
    By MikeAber in forum CNC Machine Related Electronics
    Last Post: 11-04-2004, 08:28 PM
  5. Limit switches and home switches
    By viktorcnc in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 08-03-2004, 12:11 PM
