585,992 active members*
5,238 visitors online*
Results 1 to 12 of 12
    Feb 2013
    38
    AWC608 and LaserCAD connection weirdness
    Hi everyone
    Okay - new minor problemette I'm encountering.
    Have a new AWC608 with LaserCAD software - both working perfectly... apart from one thing:
    1) I click 'Download'... the ''download document' box appears (as it should)
    2) I click "Download document" bottom right - another box pops up saying 'loading document' (as it should),
    but there it lock up.
    It will sit there, pretending to load a document forever - this little dialog box is unclosable... and (so) locks up the whole of LaserCAD. The only way of getting it back is to physically disconnect the USB cable whereupon it says:
    "communicating unsuccessful"
    allowing me to close the download dialog boxes.
    Then when I try it again, it sails through fine.
    Then when I try it again, it locks up again.
    Basically I can't get it to communicate with the board without physically unplugging the cable (every time).
    Any ideas on how to get it to communicate normally?
    Feb 2013
    38
    Re: AWC608 and LaserCAD connection weirdness
    I guess nobody knows
    Ok - go meta - does anyone know where I can get support for AWC 608 controllers running with LaserCAD?
    I'm having to unplug then replug the USB cable every time I try to upload anything. It's sub-optimal.
    Jan 2007
    723
    Quote Originally Posted by Nickwit View Post
    I guess nobody knows Ok - go meta - does anyone know where I can get support for AWC 608 controllers running with LaserCAD? I'm having to unplug then replug the USB cable every time I try to upload anything. It's sub-optimal.
    Where did you buy your DSL from? If you got it from light object, you can post on their forums and get help there.
    http://www.glenspeymillworks.com Techno LC4896 - 2.2Kw Water Cooled Spindle | Moving Table Mill from Omis 3 CMM, 500Lb granite base | Epilog Legend 32 Laser Engraver
    Feb 2013
    38
    Yea - the name Light Object comes up quite a lot - I got mine from Aliexpress though - worked out about $100 cheaper, although I guess I'm paying for that now.
    Jan 2007
    723
    What is the firmware versions you have installed? You can get that info off the laser.
    Feb 2013
    38
    Hiya.
    Main Board : 7.14.08.22
    LCD Board : 5.13.09.15
    LaserCAD V6.92
    Jan 2007
    723
    Try connecting to the laser through Ethernet.
    Feb 2013
    38
    Well that believe it or not, is an absolutely brilliant idea, which I hadn't thought of
    Unfortunately, it turns out that ethernet works even less well than USB - ie: I get no life out of it at all. I struggled with it for about an hour, but no sign of life. Could be any number of things.
    At least USB works 1/2 the time... I'm just learning to live with it basically - every time I need to download something, it takes 2 goes - one to lock up the PC, which requires a USB cable unplug... one to actually do the download.
    It seems weird to me that there could be a company making these things, but there's no support.
    Jan 2007
    723
    I'm sure if you learned Chinese your support would be better.
    Feb 2013
    38
    Really? I could probably find someone who speaks Chinese.
    Jan 2007
    723
    Once you can find someone who speaks Chinese, you can ask at the manufacturer's website.
    http://www.sztrocen.com
    Feb 2013
    38
    Quote Originally Posted by Pplug View Post
    Ah - I might do that then. Thanks.
  1. How to Change from 6515 to AWC608
    By wolfau in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-06-2016, 07:32 AM
  2. LaserCAD does not communicate proper feedrate and power to AWC608 DSP
    By wontpontificate in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-22-2015, 07:04 PM
  3. LaserCad / AWC608 micro-issue : Scaling
    By Nickwit in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 11-06-2014, 04:41 AM
  4. Convert WK Laser LC1290 leetro to AWC608 - Vic, Aus
    Last Post: 03-25-2014, 12:20 AM
