585,991 active members*
5,442 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Help!!! Touch probe grounding through spindle???
    Jul 2010
    159
    Hi guys
    I have a 2.2kw air cooled spindle and all my electronics running through a pmdx 126 controlled by mach3 using big Tex blue screen. OK now it all works fairly well but my setup means I have to connect a clip to the router bit and it lowers down to the touch plate, now the problem I have is that in between tool changes it takes off with my clip attached so my question is how do I set it up without having to put a clip on the router bit like what's shown in his videos. When I touch the touch plate to the router bit without the clip attached the green light in mach3 flashes intermittently like its not stable .
    Chris
    Jul 2010
    159
    Re: Help!!! Touch probe grounding through spindle???
    Anyone have any suggestions?
  1. Touch Plate Grounding to 110V / 220V
    By Quada in forum CNC Machine Related Electronics
    Last Post: 09-16-2014, 04:18 AM
  2. 3D touch probe
    By bschwand in forum MetalWork Discussion
    Last Post: 12-26-2013, 10:06 PM
  3. Replies: 12
    Last Post: 06-05-2013, 06:05 PM
  4. cnc touch probe
    By shawnc515 in forum Uncategorised MetalWorking Machines
    Last Post: 09-30-2010, 11:10 PM
  5. touch probe
    By basswakr in forum CNC Machine Related Electronics
    Last Post: 08-14-2010, 02:18 PM
