585,752 active members*
3,895 visitors online*
Thread: Bend-Tech-ez
Results 1 to 6 of 6
    Apr 2006
    1257
    Bend-Tech-ez
    Does anyone use any of the Bend-Tech products?
    http://www.2020softwaresolutions.com/products.htm
    If so what do you think of them and what type of things would I have to be doing to justify the more expensive packages (Such as 'Pro' or 'SE').
    Thanks.
    Feb 2004
    361
    I tried the demo versions a while back, with 4" radius die and only 2" material, and the generated measurements were pretty accurate.. I used an old Hossfeld to do a bit of bending and the results were acceptable..
    The main thing I noticed in SE was the ability to simulate bending, nice if you have an automated bender..
    I never did buy it as it was just a few bends that the demo was able to generate, and I do very little bending lately..
    enjoy..
    Apr 2006
    1257
    thanks vladdy. I tried the demo, but haven't chosen/bought a bender yet so couldn't test the program for accuracy.
    Feb 2004
    361
    I set it to generate measurements in 16ths, and just used a tape measure and marker to layout on the pipe...and the degree wheel on the hossfeld..
    final result laid down to about 1/8" on the tabs, bit of a squeeze and it was perfect...error was 'likely' in my measurements and bend angles, plus I didn't use the exact 4" die, or 2" aluminum pipe that the demo supports..
    close enough...
    enjoy..
    Aug 2004
    48
    I own the Pro version and it is an excellent program even though it is a pain to set up. Documentation is much easier to do in this software then in my previous ones I have used. I have been happy with it
    Apr 2005
    43
    check out www.offroadfabnet.com people that created bend tech own this forum. There is a lot of support and a lot of people on there that use bend tech to create roll cages and whatnot
