585,589 active members*
2,762 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Sink Electrical Discharge Machining
Page 1 of 2 12
Results 1 to 20 of 21
    Apr 2006
    1257
    What is SEDM?
    What do you use it for?
    What are its advantages/limitations.
    Just asking after coming across this:
    http://www.camtronics-cnc.com/
    (SEDM in 'Products' section)
    Aug 2006
    246
    It might be referring to a traditional or ram type of EDM where the electrode is "sunk" into a part vs. a wire EDM that uses a wire to profile. I've heard these machines referred to as "sinkers" many times...:cheers:
    Apr 2006
    1257
    Is that the type of machine used for cutting foam?
    Aug 2006
    74
    no
    it's used cut everything that cunduct electricty .we use it to cut hardened steel and weird shapes.
    excuse. i dont write much often in english
    den
    Aug 2006
    246
    An EDM(wire or otherwise) can cut any material that will conduct electricity. It basically works like a gigantic spark plug. Electricity is fed through the electrode(usually copper or graphite) When the electrode comes close to the part, the voltage in the electrode causes multiple sparks to "jump" the gap between the electrode and the part, thereby eroding or cutting the part. I must admit, I've never heard of or seen anyone cut foam on one...
    Aug 2006
    74
    Apr 2006
    1257
    Thanks all. I knew what a foam cutter was and thats why I asked. It didn't seem like it would be used for cutting foam. Why use an EDM instead of a Plasma Cutter or milling machine, is there a specific niche that it fits that cant be done with another machine? Thanks.
    Aug 2004
    145
    Quote Originally Posted by diarmaid View Post
    Because EDM can do 3-axis vs the plasma cutter's 2-axes
    or miling machine
    Because it can cut in hard to reach spots (e.g. odd shaped undercuts) and doesn't care about the material hardness
    Nov 2005
    14
    sinkers are used to do a lot od mold work. you can burn a sharp internal corner. The are very acurate.
    Jul 2005
    12177
    .... Why use an EDM instead of a Plasma Cutter or miling machine, is there a specific niche that it fits that cant be done with another machine? Thanks.
    EDM can cut fully hard tool steel which is more or less impossible with a milling machine. Plasma cutter can cut hard material but is limited to thinner material than EDM is much less accurate and because it melts the material away it leaves a heat affected zone adjacent to the cut surface. The material adjacent to an EDM cut is pretty much un-affected. Sunk EDM can do weird shaped through holes or blind holes that could be impossible by any other method.
    Aug 2006
    246
    EDM machines are extremely accurate with some machines approaching grinder accuracy. They are generally special purpose machines and not all shops will have a use for them. Unlike traditional milling machines, EDM's never touch the part and therfore leave the cut surface stress free. They can cut extremly intricate features, such as thinwalled parts where a milling machine would cause vibration, square holes with perfectly sharp corners, and odd shaped 3d contours to name a few. A sinker EDM like the one that started this thread, can be used to finish a mold or die cavity and eliminate hours of polishing time. A wire EDM....well just think of a guitar string that can cut 64 HRc steel... Charmilles, Fanuc, and Mitsubishi are some of the larger EDM manufacturers. Check out their websites for more info....:cheers:
    Feb 2006
    1187
    hey Diarmaid, I just started working at a tool & die shop, they have 4 different edm machines, I have not seen them running but I have seen the results, and they are amazing machines, cut thru 4" of aluminum like butter, very smooth finish. I told the boss to call me when they are goimg to run edm again and I,ll come in early just to watch. :-)
    Apr 2006
    1257
    Cool. Thanks ZipSnipe. Cant wait to hear about it. If your boss is really friendly, maybe tell him there's an Irish guy on the internet who knows nothing and would love to see some pics! (Since its a new job maybe just a written report sill suffice for now)
    Feb 2006
    1187
    Yeah I,ll post some pics soon, need batteries for the camera. :-(
    Jul 2006
    51
    You can do some amazing things with an edm machine. I remember once we had to cut an CUSTOM internal thread, 2" diameter. The guy was burning it in in z axis while spining it in c axis.....puirty cool to see.
    it's also very usefull for buring out small broken taps, among aother things
    If you ever got a chance to watch it "burn" make sure you put your hand on the metal that holds the carbon. (if you like getting hit by a big joilt)
    oh and make sure you dont smoke near it....the evaporated gas from the oil is EXPLOSIVE, i've seen it light up the rubber cover on the machine...and i've seen it blow up carbons.
    Aug 2006
    74
    hi diarmaid.this was cut on a wire edm
    C:\Documents and Settings\All Users\Documents\Mes images\Échantillons d'images\REALIS_FEUILLES.jpg
    Aug 2006
    74
    sorry. dint work
    Sep 2006
    6463
    Hi all, for all those DIY people out there, you can build your own EDM. Just takes a bit of knowing how it works. A number have been built using a stepper motor to drive the electrode (copper) up and down and a control board to work the stepper. Power for the burn was supplied by an old valve radio transformer and a capacitor. It's not rocket science, and neither is a home built cnc mill.
    Ian.
    Jul 2007
    37
    We have a Makino sinker EDM in our department that we use to make face detail on hardened tool steel thats used for pressed metal tooling. Awesome machines that can do alot of high precision work. We work with dimensions withing plus or minus .003 mm They're highly accurate
    Sep 2006
    6463
    Hi Alex, will EDM work on Cabide?
    A mate of mine wants to take some plain carbide tips and form chipbreakers on the ends, bit too fiddly to try and grind even with a diamond grinding setup, which he hasn't got.
    Ian.
Page 1 of 2 12
