I'm interested in buying a personal CNC like the Tomach PCNC 1100 for small production runs and projects . I have already got a benchtop manual lathe and milling machine but would like to purchase a CNC if it makes sense. I have a few questions if someone could answer would be much appreciated.
1) How easy is the software to learn? I use Autodesk Inventor for modelling and I have seen that theres a programme called InventorCAM that can be used. Has anyone used this? Is it pretty straight forward if you have used inventor and have some knowledge in lathe work?
2) Is the Tomach PCNC 1100 the best option for me? I want something quite compact. I will mainly be cutting soft metals like copper and aluminium with the occasional stainless steel project. My budget is around £15,000. Does anyone know of a better CNC machine?
3) I will be doing a combination of lathe work and milling. Does this mean I would have to purchase a CNC milling machine and CNC lathe as I would if I were to carry on doing it manually? Or could the milling machine with the 4th axis be used to do lathe work?
Any help would be greatly appreciated.
