Hi guys,
I am building a OX CNC - OpenBuilds OX CNC Machine | OpenBuilds
But have increased size of the CNC two fold so the gantry is 1m (3 feet 3⅜ inches).
It is only using 2x 20x60 v-slots for gantry and they are only fixed to gantry plates and not to each other.
I am concerned with stability and would like to glue them or join in any other way to add a bit more stability.
What are the options available to me?
- Is there a special t-nut that can connect two v-slots next to each other?
- I looked at glue for aluminium and from what I could deduct it is a big no-no, and if it is to succeed at all, I have to scrape the finished v-slot surface to even stand a chance.
- Drill a hole through both extrusions and use a screw? I only have 3mm (0.118 inches) from side of extrusions to z plate so I would have to run a screw through one of the channels on extrusion sides (seems a bit impractical, honestly)
Once I am up and running I can create new gantry plates that can accommodate 20x80 extrusions and that can potentially solve my issue?
Or maybe even add a third extrusion?
Let me know if I'm not making any sense.
Regards,
Milo
