585,712 active members*
3,935 visitors online*
    Aug 2013
    21
    ma860h alarm indicator led
    Today 2 of my machines ma860h alarm indicator led were on when I turned it on, the manual says that
    "Short-voltage and Over-voltage protection When power supply voltage exceeds 123VAC or +173VDC, over-voltage protection will be activated and Alarm indicator LED will turn on."
    My problem is that all my Microstepping Driver units run from the same power converter and only 2 of the 3 are showing the red LED's, to test a theory I unplugged the power from the units that were showing the red LED's and swapped it over with the unit that was showing the green LED's and when I turned it on the LED stayed green and this happened with the power for the other unit. I'm wondering if there is a reset that I don't know about.
    Can anyone shed some light on my problem.
    May 2005
    1397
    Re: ma860h alarm indicator led
    I would contact support at the company that makes or sold you that driver.
    James hosts the single best wiki page about steppers for CNC hobbyists on the net:
    http://www.piclist.com/techref/io/steppers.htm Disagree? Tell him what's missing! ,o)
  1. Stepper Motor Driver MA860H power supply connection
    By airtruk in forum DIY CNC Router Table Machines
    Last Post: 10-24-2013, 03:06 AM
  2. Ma860h driver faults help needed
    By wavewizards in forum Servo Motors / Drives
    Last Post: 04-24-2013, 08:34 AM
  3. LED indicator
    By neric in forum CNC Machine Related Electronics
    Last Post: 11-17-2011, 11:59 AM
  4. Replies: 11
    Last Post: 02-28-2010, 08:33 PM
  5. Dial indicator
    By hkrok in forum News Announcements
    Last Post: 08-17-2007, 01:49 AM
