I have a MAXNC10CL that has not run right since day one, and it has died altogether once. Now it is basiclly useless again. The wll not run hardly at all. I swapped out the X micro from the unused A driver, I also swapped out the TIP120's.
The motors are 8 wire uni. 210 oz, 2 amp. Their system runs in quadrature and requires special drivers for MACH3, for which I have never had it really work well, but is prefernce of machine software There are encoders attached which I can lose.
Please tell me if this is semi workable as a cheap and dirty temporary solution:
I keep their controllerbox, with limit switches and parallel port in tact on their box so less to reinvent. I cut traces on their board to access the input pins 4,5,6,7,8,9 pins. for step and dir. I keep their 4 TIP120's per motor in tact, cut the traces to them.
Either A. write some simple code for an SX to receive the Step an Dir, and output the appropriate sequence to the already existing mosfets, or B. Get a simple driver like an EDE1200 6 wire driver. The 1200's are a shiort drive, the SX are on hand as well. I also have th SX28's on hand and could perf board the whole thing.
Hopefully someone can say this is workable or not. MAX wants 450 for just the stuffed board, but why try that again when it never worked, and I am still locked into that company like a prisoner. Gecko is 3 drives at 120 ea plus a PS, but would work, but would require some other extrenal box plus rewiring everthing.
Thanks for any suggestions.
