Re: Help finding a Spindle for Wood, Plastic, and maybe Aluminium?
Spindles are simply far superior to consumer wood routers when it comes to CNC machining. The normal wood routers on the market have terrible runout, low life bearings compared to better tools, and are simply not designed for the duty cycles of cnc machines that can be running 8 out of every 24 hours for weeks at a time.
Spindles are far quieter and more accurate, and will last much longer than routers. I prefer water cooled spindles as you don't have any air circulation or fans to worry about clogging up with dust. Some prefer air cooled, but unless you have a very good dust extraction system setup, you'll be sucking and blowing dust and waste through the air path.
I have several of the cheap Chinese ones, in a variety of power ratings, and generally tend to use the 1.5kW one for most things. Depending on your wallet you could get a good Hitachi VFD to match the commonly avaliable spindle, or just a VFD/Spindle combo of the Huanyaun (or something like that anyway) variety. 'Despite all the bleating from people here about crappy Chinese stuff, I haven't actually seen many posts at all from people that actually had experienced failure of the cheap Chinese VFD's/spindles. The last 2.2kW VFD/spindle I bought off ebay cost me around $380 inc shipping, which I though was pretty damn cheap! Certainly far cheaper than some wood routers I've bought.
I'm more than happy with mine. I use it for wood/plastics/aluminium routinely.
cheers, Ian
It's rumoured that everytime someone buys a TB6560 based board, an engineer cries!
