585,557 active members*
3,420 visitors online*
IndustryArena Forum > MetalWorking Machines > Hardinge Lathes > Hardinge HC-AT threading attachment
    Mar 2009
    88
    Hello,
    I bought this machine which had the threading attachment but is missing this arm(the book refers to it as the support bracket which rides on a block bolted on the turrett.) The manual says it's used when you cut coarse threads and/or harder material(i.e., stainless).
    Does anyone know where I might find the arm?
    Thanks in advance
    Feb 2005
    54
    Re: Hardinge HC-AT threading attachment
    Did you ever find out?
    I just got an HC with the AT threading attachment and mine doesn't have that either.
    Do you have a PDF of the threading attachment docs? Could you please share?
  1. Hardinge Conquest 42 G76 Threading Problem
    By Phoenix123 in forum Hardinge Lathes
    Last Post: 06-21-2014, 08:20 AM
  2. Hardinge threading lathe calibration
    By ccarlsen in forum Hardinge Lathes
    Last Post: 02-22-2012, 11:27 AM
  3. I.D. threading Fanuc 18t Hardinge T42
    By rwpbrian in forum Fanuc
    Last Post: 02-04-2012, 08:30 PM
  4. Hardinge threading code
    By Pontiff51 in forum MetalWork Discussion
    Last Post: 03-16-2009, 05:37 PM
  5. Anyone knows what's this attachment and what's the use??
    By cbucner in forum MetalWork Discussion
    Last Post: 04-04-2006, 04:04 AM
