I'm in the process of retrofitting a DM45 mill, a RF45 clone from penn tool co. I did the head first, all the ususal, new abec 7 angular bearings with kluber grease, vfd, belt drive, power drawbar with tormach tooling. I am very pleased so far EXCEPT with the spindle bearings.
I got the head pretty much complete, did the bearing breakin monitoring temps, and it was time to put a cutter into some metal. I had real bad chatter problems. I concluded it had to be slop in the spindle bearings after exhausting all other possibilities. I tore it back apart and checked things much more carefully this time. One bearing looked and felt very slightly bad. ALSO, the upper bearing always ran much hotter than the lower during the breakin. It is also worth noting that the sound of the spindle changed over the hours of breakin, it had a extremely slight raspy sound at the end that was not there at first. Checking things much closer, I concluded the press fits were too tight and this "possibly" was preventing the spanner nut from pulling the shaft/bearings up together and getting proper preload. I "think" one bearing preloaded and the other had slop. I cannot swear to this because its about impossible to veryify with the spindle assembled. It is worth noting that the press fits were such that I had to heat the housing and freeze the bearings to get them installed.
What I seen on disassembly, that I did not like, was the bearing outer races were far too tight a press fit into the spindle housing. I took carefull measurements but do not have them on hand at the moment. The spindle shaft into the inner races was not nearly as tight. When I say those outer races were very tight I mean the press fit into the spindle housing is such that disassembly is impossible without destroying the bearing. The original factory bearings fit the same way.
At this point, I believe the outer race / housing fit is the problem. I am thinking the spindle bore for the race has to be opened up a bit to lessen the press fit. How to accomplish this easily is another matter! !!! Much reading on the matter has found that the bearing press fit is very important with precision bearings and plays a part in determining the installed internal clearances.
So............... my questions are:
What have you other guys that upgraded spindle bearings experienced in how tight the press fits were?
Did anyone have to rework their spindle housing to loosen up the press fits? How did they do this? I am just about positive this needs to be done but a method for the home shop leaves me scratching my head.
I have not installed the second set of bearings and have the spindle apart yet. I want to take every precaution to get it right this time so I am looking suggestions for the collective knowledge of those that have done it here.
Any help / suggestions would be most appreciated.
