585,767 active members*
4,039 visitors online*
IndustryArena Forum > CNC Plasma, EDM / Waterjet Machines > Torchmate > Need to find replacement Stepper driver board for TM2
    Good Morning,
    I am looking for a replacement Stepper Driver Board (OD-8A-M) for my TM2. Torchmate is back-ordered till the end of the month and need to get my machine back up. Have looked for a direct replacement and have come up with nothing. Anybody know of a cross reference for this part? I've attached pictures of the bad board. Any help would be appreciated.
    David DeMattia
    Sleeping Dragon Studios, LLC.
    [email protected]
    Attachment 259196Attachment 259198
    Jan 2011
    91
    Quote Originally Posted by dndemattia View Post
    Good Morning,
    David DeMattia
    [email protected]
    I believe it's a flash cut CNC driver. Could also be Applied motion.
    Re: Need to find replacement Stepper driver board for TM2
    Thanks! I found last year that Flashcut will not talk to Torchmate customers. I did find something at Applied Motion that might work. It's an STR-8 driver. It looks almost identical to my current one. Will update the group when I get it in to see if and how it works. Thanks again.
    Hello All,
    Just wanted to update you on my results for finding a replacement stepper driver board cross reference. I found that the Applied Motion STR-8 works the same as the TM part and is slightly less in price. The Applied Motion part came in today and after setting the DIP & Rotary switches, I just plugged in the new board. All the connectors are the same, no rewiring. After powering up my TM, I did some manual tests then cut one of my more complex designs. Worked great. So, if you are looking for a second source for the TM2 stepper driver board that I needed (based on my results and current board design) it works fine. David
    David N. DeMattia
    “Like” us on Facebook!
    651-307-9288
    Here is a closeup of the switch settings. Rotary Switch=B. DIP = 7 & 8 Off.
  1. Help picking replacement stepper driver board
    By herring_fish in forum Hobby Discussion
    Last Post: 02-15-2012, 04:55 AM
  2. Stepper driver board
    By 4lowie in forum Australia, New Zealand Club House
    Last Post: 09-09-2011, 09:31 AM
  3. 6 leads stepper motor connect to TB6560AHQ stepper driver board
    By wf1318 in forum Stepper Motors / Drives
    Last Post: 07-25-2010, 08:19 AM
  4. need to find a replacement stepper motor urgently
    By rocabig in forum Australia, New Zealand Club House
    Last Post: 05-27-2008, 10:57 PM
  5. Where can I find X-Axis Driver Board for Interact 412 VMC ('89)
    By Skin in forum Bridgeport / Hardinge Mills
    Last Post: 01-28-2008, 06:04 PM
