585,978 active members*
4,586 visitors online*
    Sep 2006
    z axis problem
    Hi, i am currently working with turbocnc version 4.1 and i am having problem after problem. A recently acquired problem was that the z-axis is cutting too deep. The specific line from the g-code and the actual cutting measuremnt are way off. We had a theoretical distance of .4 and were getting something closer to .6 for the actual. I would be most appreciative to any help possible. Thanks
    Mar 2004
    1806
    The first things that come to mind as you haven't told us anything about the machine or setup is:
    1. Inproper setup of the steps/inch ( these should be setup by actual measurement and not theroretical guess)
    2. Backlash in the system. (your setting of z=0) and due to backlash, the tool is being "pulled into" the work. Could also be a collet that is not tight enough and it is being pulled out of the holder/collet.
    Art
    AKA Country Bubba (Older Than Dirt)
