585,754 active members*
3,801 visitors online*
    Feb 2008
    243
    Laser works 6 USB driver
    I had my 100W laser running fine last Feb. but haven't used it for a while. When I connected the PC to the laser and click on USB auto it gives me a communication error.
    I checked my USB port and it works fine. I can even d/l a file using the USB stick and then plug that into the USB slot on the laser and it loads fine. I know my cable is Ok because I did a continuity test on all 4 pins.
    Then I really screwed up and reloaded the software and the USB driver . It says it installed properly. Now when I run laserworks from the desktop I get a USB popup menu and when I click ok I get a communication error and now it wouldn't let me proceed. I think the problem is with the laserwork USB driver. I tried reinstalling it several times with the same negative results.
    So I think that somehow either the USB driver is corrupted or it is in the wrong path.
    Can anyone email me the English USB driver or tell me the path that the driver is located on as well it's file name.
    Dan Mauch
    Re: Laser works 6 USB driver
    Hi Dan
    we have the same problem as you did.
    we have just purchased a laser that has supplied Laserwork v6 as its program on a usb stick. We have loaded the program & all seems OK except that te get 'communication error' when we try to send to the laser.
    What do we need to do to fix this.
    regards
    Jim Tapscott
  1. Fiber laser marking machine works
    By mornlaser2014 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 07-23-2014, 01:04 PM
  2. Fiber laser marking machine works
    By mornlaser2014 in forum News Announcements
    Last Post: 06-12-2014, 09:11 AM
  3. Tachus42 Driver >> Works in Kcam 4 and NOT working in Mach3
    By king master in forum Mach Software (ArtSoft software)
    Last Post: 12-18-2013, 12:12 AM
  4. Replies: 0
    Last Post: 05-01-2013, 05:00 PM
  5. Replies: 14
    Last Post: 03-16-2013, 02:22 AM
