Hey guys,
This might be an easy fix, but I exported G-code yesterday using Fusion 360 CAM, and the G-code works just fine. However, after the cut is finished, the machine is returning to it's "home" position (Ref All Home - Mach3) instead of the zero/zero point that I specified in Mach3.
Basically, in Mach3 you can have a custom zero/zero point anywhere on the surface. The tool path that I programed yesterday exported the G-code just fine, but why is it telling the machine to return to "home" instead of my custom zero/zero point?
Is there an easy fix for this?
By the way, I'm using a CNC router.
