Originally Posted by
ToolChatter
I have an old M-40 controller that doesn't appear to allow this.
My plan is to load each tool and touch off on the part and record the offset for each one from the longest tool. Then I'll enter the tool data into BobCam with the length of the longest tool being approximate but the difference between all the tools being accurate.Then I'll set up the WCS to be at the top of the part. The problem I'm having with that is that I can't figure out how BobCam uses this info. I ran a program with 2 tools where the longer tool is used in the first operation. I set the WCS at the top of the part and the first operation worked fine. The 2nd tool was about .25" shorter, which I had entered into the tool info in BobCam, and it went to the same place as the first tool, so the feature was .25" too shallow. I tried using the "override offsets" option in BobCam, but when I entered the diameter offset of 9.52mm (for a 3/8 endmill), it changed it to 10. Anyone know why it's doing that? Anyone know why it went to same Z position for 2 different length tools?
Tom
