585,883 active members*
4,883 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > FlashCut CNC > looking to upgrade steppers & drivers.
Page 2 of 2 12
Results 21 to 28 of 28
  1. #21
    Jan 2011
    91
    Re: looking to upgrade steppers & drivers.
    Yes it's been up and running for a good while now and working good.
  2. #22
    Jan 2006
    107
    Nice! I'm interested in the speeds you are getting. I built a 5x10 heavy duty gantry router, I use a router, mill head, drag knife, ..., and have an outrigger to hold a plasma torch out over a water table that connects to the main table. It has worked great for ~15 years. I want to build a 5x12 dedicated plasma table with a light weight gantry to get the speeds up for light stuff. I cut from heavy 1" down to rusty .020" roof metal.
    If you don't mind a few questions,
    Did you use 23 or 34 motors?
    What oz rating?
    Looks like you have 2 motors on the gantry travel?
    What drivers did you use?
  3. #23
    Jan 2011
    91
    I'm running str8 drivers and ht23-603 motors from applied motion technologies with two motors for the x "long" axis.
  4. #24
    Jan 2006
    107
    Thanks modelaratrod, what is the max speed you can cut at, does it do corners at a good speed?
  5. #25
    Jan 2011
    91
    The issue I have is the torque sensing AVHC, with the plate flexing I've had to slow down. I'm currently waiting for my shipment of a flashcut stingray height control and version 8 software to give me ohmic sensing and corner lockout/lookahead. I'm currently cutting 14g at 150 ipm.
  6. #26
    Jan 2006
    107
    Thanks, I program at 300 ipm, but mine also slows to about 150 on tight corners. I'm thinking I should go with 34 motors.
  7. #27
    Jan 2011
    91
    I'm also changing the cam roller set up with Parker cassette's, should be a big improvement.
  8. #28
    Jan 2011
    91
    If that doesn't get me cutting at cut chart speeds 34's will be next!
Page 2 of 2 12
  1. Tell me about drivers and steppers
    By SwampDonkey in forum Benchtop Machines
    Last Post: 03-28-2012, 11:40 PM
  2. Steppers and drivers - need help
    By harisfifo in forum Want To Buy...Need help!
    Last Post: 02-18-2012, 11:09 AM
  3. Connecting steppers to drivers
    By speedhound in forum Stepper Motors / Drives
    Last Post: 01-20-2011, 06:57 PM
  4. Steppers, drivers, electronics in the GTA?
    By ThomD in forum Canadian Club House
    Last Post: 01-13-2011, 01:37 AM
  5. Steppers and drivers
    By domar in forum Stepper Motors / Drives
    Last Post: 03-21-2008, 10:11 AM
