here is my build " i have never done such a thing before by the way"
Great job, there's not a lot of things that are cooler than having a CNC machine! Rolling your own spindle too, that's impressive, and not a simple task by any means. Those bearings though kinda look like normal radial bearings? Are they radial or AC's, as normally they'd be pairs of annular contact bearings to stop vertical movement of the spindle. Same as what you'd use for the drivescrews.
Congrats on the build though, looks like your off to a flying start!
cheers, Ian
It's rumoured that everytime someone buys a TB6560 based board, an engineer cries!
the bearings are normal exept the upper is contact. the spindle has a oil seal at the but and filled with transfergear case oil for lube
Heii.....
here we producing most advance,reliable Hydraulic drive shaping machine,cone Pulley drive Shaping Machine with Automatic Lubrication System,Screw press,Hydraulic press at reasonable price across India with reasonable cost.
Contact Us: 9872891455
Address:G.T.Road, Miller Ganj, Ludhiana.
Attachment 361602Attachment 361604Attachment 361606
just got some spare time
