585,662 active members*
3,328 visitors online*
IndustryArena Forum > Machinery Manual, Brochure / Photo Archives > Machinery Manuals / Brochures > TC5530 3 axis CNC motion controller for punching drilling lathe milling servo stepper
    Dec 2012
    17
    Attachment 260116
    Product Introduction
    The TC55 panel-type motion controller (CNC system) uses high-performance 32-bit CPU. The drive device adopts subdivision stepping motor or AC servo motor. It is equipped with LCD monitor and fully enclosed touch-type operating keyboard. The system has high reliability, high precision, low noise, easy to operate etc. This controller can control 1-3 motor motion and realize Point to Point, linear interpolation, circular interpolation and other operations. It has loop, jump and simple PLC functions etc. Simple and clear parameters bring you convenient and fast operation. Input/output setting functions are convenient for your to use and maintain,and applicable to all kinds of 1-3 axis motion device.
    Product features:
    The boot screen can be modified
    Controller or upper computer dual-mode programming
    Independent 24V power supply reverse connection protection
    IO optically-coupled isolation
    Output short circuit protection
    Manual positive or reverse rotation can be controlled by the external switches synchronously
    Simple PLC logic The parameter area password can be set
    Applicable product type:
    CNC drilling machine system, CNC lathe system, CNC milling machine system, CNC grinding machine system cutting machine control system, welding control system, dispenser control system, feeding control system displacement platform, one-dimensional control platform, two-dimensional control platform, three-dimensional control platform threading machine control system, screw-driving machine control system spraying production line control system, assembly production line control system, the meter counter control system
    Technical characteristics:
    Automatically execute, Actual running, Empty running, Single-step execution, Terminate program, Start and Pause function;
    Manual operation: Manual high speed, Manual low speed, Jog operation, Back to program zero, Back to mechanical zero;
    Program management: Edit program, Program read-in, Delete program and Save program;
    Parameter settings: Set various control parameters of processing and operation, with best status of processing effect.
    System parameters:
    High-performance, high-speed 32-bit CPU
    High-grade black and white double color LCD monitor (resolution: 192* 64)
    Special motion control chip (signal output: 5V TTL)
    Universal customizable input / output (16 photoelectric isolated 24V inputs, 8
    relay outputs)
    User processing program memory (can store 9600 commands)
    Minimum data unit 0.001 mm
    Maximum data size:99999.999mm
    Maximum pulse output frequency 150KHz
    System main functions are automatic, manual, program editing, self-check, settings, etc.
    Installation:
    Panel type installation structure
    Dimension: 172 x 94 x 30, installing size 164 x 86
    Power supply requirements ≥ DC 24V/40W
    Environmental requirements:
    Working temperature: 0-60 centigrade
    Relative humidity: 5 - 90% no condensation
    May 2015
    Re: TC5530 3 axis CNC motion controller for punching drilling lathe milling servo ste
    How use for a circle operation
    Dec 2012
    17
    Hi Friend,
    You calculate the gear ratio and then you can run the motor by degree, or round, or division. May i have your email so i can send you manual? Or you can contact [email protected]
  1. Replies: 2
    Last Post: 12-30-2014, 10:28 AM
  2. Replies: 0
    Last Post: 12-02-2014, 04:13 AM
  3. Replies: 0
    Last Post: 12-02-2014, 02:37 AM
  4. 4 Axis High Grade Milling/Drilling CNC Controller
    By adtechcn in forum News Announcements
    Last Post: 10-24-2012, 11:03 AM
  5. JAF Motion - 4 Axis Stepper Controller
    By jafgraphics in forum News Announcements
    Last Post: 12-03-2008, 03:06 PM
