585,741 active members*
5,011 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Dynomotion/Kflop/Kanalog > MPG: Can I hook up directly to JP6... MPG is 5vdc logic? Do I need to use Resistors?
    Jul 2004
    235
    Greetings,
    On my milling machine, I want to add a MPG.
    MPG is 5vdc logic?
    Do I need to use Resistors inline to each input, to drop the signals to 3.3 volts?
    Does anyone have a schematic to share, that shows this... on JP6?
    Sincerely,
    Robot & Machine Design - BLUECNC4, GreenCNC3, RedCNC2L, SilverCNC2; CNC Software!
    www.truemachinedesign.com - - - - - - - - - - - - - www.truemachineautomation.com
    May 2006
    4045
    Re: MPG: Can I hook up directly to JP6... MPG is 5vdc logic? Do I need to use Resist
    Hi jeffserv,
    KFLOP 3.3V inputs can be damaged if driven higher than 3.8V. However in most cases you can connect 5V TTL signals directly to them. 5V TTL signals are only required to drive higher than 2.8V. Unfortunately they don't usually specify the maximum they will drive. To test connect a 150ohm load to the output and check the high voltage with a voltmeter. If it is less than 3.8V then it can be connected directly without a problem. I have never heard of a case where it is a problem.
    HTH
    Regards
    TK
    http://dynomotion.com
  1. Going to hook up a network/serial line to send programs directly to machine from pc
    By J S Machine in forum Computers / Desktops / Networking
    Last Post: 05-24-2011, 04:51 PM
  2. 12vdc from 5vdc
    By TravisR100 in forum CNC Machine Related Electronics
    Last Post: 04-03-2009, 08:32 PM
  3. Sensing Resistors vs Current limiting Resistors
    By whitney in forum Hobbycnc (Products)
    Last Post: 11-06-2006, 06:29 AM
  4. Where to get +5vdc for my Gecko????
    By Apples in forum Gecko Drives
    Last Post: 09-05-2005, 12:45 AM
  5. How to control 5vdc logic relays with PC
    By keithorr in forum Computers / Desktops / Networking
    Last Post: 07-24-2004, 06:49 PM
