585,888 active members*
3,972 visitors online*
Results 1 to 6 of 6
    Dec 2014
    AXIS movement calculation
    G91G01X30Y40F100
    in this line x axis will move F100 OR less feed rate..
    Re: AXIS movement calculation
    Slower.
    Dec 2014
    How to calculate x axis movement feed rate
    May 2012
    22
    it will go slower most of the time, but if Y axis is already at 40 X axis will go at F100
    F100 is the maximum feed rate to reach your starting area for both X and Y axis
    so if Y axis is at 40 on your table you just have 1 axis to moved so X axis will move at F100
    if X axis is at 0 and Y axis is at 10, both X and Y axis will go at the same feed rate because they have to move 30 off on each axis
    so the feed rate is a combination of both x and Y axis
    2932
    Quote Originally Posted by 1jfhoule1 View Post
    His program has G91 so it's incremental. The length of the interpolated line is 50, so at F100 it will take .5 minutes to make the move. In .5 minutes X will move 30, so unless I miss my guess, X is feeding at 60, Y is feeding at 80. But I could be wrong.
    May 2012
    22
  1. uncommanded A axis movement when doing 4 axis work.
    By Tristar500 in forum Mach Mill
    Last Post: 09-12-2014, 02:47 AM
  2. X axis differential to create Y axis movement.
    By mpatterson557 in forum Uncategorised CAM Discussion
    Last Post: 03-10-2014, 12:18 AM
  3. Replies: 1
    Last Post: 06-07-2013, 04:01 PM
  4. Grinding and unexpected axis movement if rapiding 2 axis
    By DarkSabre in forum Taig Mills / Lathes
    Last Post: 03-26-2010, 05:37 AM
  5. 4 Axis Feedrate Calculation
    By cbr120 in forum MetalWork Discussion
    Last Post: 12-12-2007, 06:20 PM
