585,982 active members*
4,549 visitors online*
Results 1 to 15 of 15
    Jan 2007
    48
    EX1047 Machine SPEC.PARAM.CLEARED.
    We have an MV40M Fanuc MF-'MT (fanuc OMC=
    It had a 910 parity alarm.
    We cleared it
    Loaded all the parameter and diagnostic
    Now we have ab EX1047 Machine SPEC.PARAM.CLEARED
    I know moriseiki protected this parameter with a diagnostic
    I don{t have a print to ladder to resolv the problem
    any person to help me with this the diagnostic o print to ladder to resolv the problem
    Willydke
    Feb 2013
    4
    Quote Originally Posted by Willydke View Post
    We cleared it
    Willydke
    Are there any advise for EX1047 message alrm after parameter import?
    Thank Tu
    Jan 2007
    48
    Re: EX1047 Machine SPEC.PARAM.CLEARED.
    I resol mo problem
    - - - Updated - - -
    my machine work
    ok
    Feb 2013
    4
    I resol mo problem
    - - - Updated - - -
    my machine work
    ok
    can you help me to solve problem of EX1047 after parameter input. thanks, Tu
    Sep 2015
    can you help me solve this ex 1047 alar in moriseiki
    Aug 2003
    21
    Hi Everyone,
    I need help too.
    Can you kindly share how to solve EX-1047 alarm?
    I have input all parameters, except DIAGNOSTICS 0660-0669
    It is impossible to input them.
    Any help would be highly appreciated.
    (Machine Mori-Seiki M300)
    With kindest regards, Igor Kozlov
    Dec 2017
    hola que tal como pudieron resolver su problema con ex 1047?
    May 2017
    clear all parameters.
    -input machine parameters and without turn off the machine input all pmc parameters.
    -Turn off the machine
    Probably some parameters of machine you will re input, because while are you enter the parameters the machine "want wich you turn off and turn on", but ignore them.
    regards
    Aug 2017
    Quote Originally Posted by aguzguerr View Post
    Que tal amigo como pudiste resolver el problema???
    Apr 2013
    12
    I resol mo problem
    - - - Updated - - -
    my machine work
    ok
    Willy
    Tengo problema con mi máquina, igual que tú, me aparece la alarma 1047 después de cargar los parámetros.
    Crees que me puedas ayudar?
    Saludos
    Rodrigo
    May 2017
    Quote Originally Posted by rodrigomex View Post
    Willy
    Saludos
    Rodrigo
    Primero borra nuevamente todos los parámetros. Después ingrésalos nuevamente, pero no vayas a apagar tu máquina aún.sin haber apagado tu máquina ingresa los parámetros del PMC. Ahora sí ya puedes apagar tu máquina y vuelve a reingresar los parámetros y ya la puedes apagar si la máquina te lo solicita.
    Saludos
    Apr 2013
    12
    Quote Originally Posted by DRETANAP View Post
    Saludos
    Muchas gracias.
    Hoy lo intentaré a ver cómo me va.
    Saludos.
    Jan 2020
    9
    Hello my friend
    Can you reply me please how you resolved your
    Ex1047 alarm of Mori seiki please help me thanks
    same problem mine MVC65-40 vmc machine
    Please help me , how you fix error ?
    I resol mo problem
    - - - Updated - - -
    my machine work
    ok
  1. EX1047 alarm
    By trx-350 in forum Mori Seiki Mills
    Last Post: 02-27-2022, 03:36 AM
  2. Machine Spec. advice needed
    By ckrantz in forum Uncategorised MetalWorking Machines
    Last Post: 11-25-2012, 01:14 AM
  3. Replies: 6
    Last Post: 10-29-2012, 11:18 PM
  4. fanuc parameters cleared
    By Mikey69 in forum Fanuc
    Last Post: 05-12-2009, 05:44 AM
  5. Absolute minimum machine spec for EMC2 latest build?
    By irving2008 in forum LinuxCNC (formerly EMC2)
    Last Post: 07-24-2008, 12:30 PM
