585,660 active members*
3,258 visitors online*
IndustryArena Forum > CAD Software > Solidworks > what am i doing wrong? - Trying to make a cylinder into sheet metal and flatten it.
Results 1 to 14 of 14
    673
    To create a pattern... Looked at some vids, but not working - is it because of my cross holes? I'm trying to flatten this part so I can make a cutting pattern.
    Tips?
    Thanks!
    Attached Files Attached Files
    Jun 2008
    562
    Re: what am i doing wrong? - Trying to make a cylinder into sheet metal and flatten i
    Try suppressing the holes and see if it works.
    Mike
    673
    Mike, thanks for the response. Tried that, but same result...
    Jun 2008
    562
    Can you post the model?
    Jan 2006
    2985
    I can't look at your model right now but is your cylinder continuous? If so, that is likely the problem. Your cylinder has to have a break somewhere so that it can be flattened. I'd draw a circle with a tiny piece of the arc missing, it should then flatten with that tiny seam being the end of the flat sheet.
    673
    I posted the model in the original post... I did put a cut through the model, and my understanding is, you pick that cut edge and "insert bend", then Flatten, and I watched videos of how to do but can't recreate
    Feb 2009
    311
    I tried to open your file and got an error.
    Take a look at this one. I tried to do this with a swept bend but it wouldn't unbend for some reason. Lofted bend seems to work though.
    C|
    673
    Quote Originally Posted by cygnus x-1 View Post
    C|
    Lofted bend eh? that sound promising - Thanks for the help... I'll check it out...
    Dec 2007
    123
    I have never been able to get sheet metal to give me a flat pattern of a part that has a compound curve. Since you do not have a straight cylinder or cone, I suspect that is the problem. Your part cannot be simply rolled/bent, So the software does not know what to do with the geometry. So here are a couple of options, Step your tapered part as a series of straight edge cones. This ends up as a multi piece part that will have to be welded. Turn your seams to run parallel to the center axis of your cylinder, and make it a multi sided part. Again these will have to be welded. How do you intend to manufacture this part? Think about the pragmatics of that, and design the part that way. Your current part cannot be manufactured in a standard roller, or a break press, you will have to do the flat pattern old school, and have a sheet metal artisan make it, or design a custom manufacturing process, if you want to keep the smooth transition taper.
    673
    Quote Originally Posted by twoartistic View Post
    Thanks for in insights. My thinking was to unroll it, cut it from 18ga sheet steel, roll it up and weld it. Couple options would be to do it two parts and weld together (tube and taper parts). Maybe it should be a regular cone? I'm reproducing an aircraft part from the 1940s. Maybe the pictures I references are deceiving. The real thing was rolled and welded, so has to work somehow. I was originally going to simulate by machining it out of billet aluminum as that shape is easy to do on a lathe... Might have to stick with that if I can't unwrap it. Good points to ponder... Will experiment more on that tomorrow.
    Sep 2010
    122
    Roll and weld a cone, then build a swage (mandrel) the shape you need it to be. use a hydraulic press to push it in. May have to build an outside mold as well.
    673
    Quote Originally Posted by inov8r View Post
    Yep, that would work, (also need to grind the inner weld face before swaging) but all that is too much effort for a one off (large) scale R/C build though. I think I'll just machine from billet. Heck, I could probably just 3d print it with a couple metal inserts for piece of mind.
    Jan 2006
    2985
    Folks are also using pressure washers for hydroforming things like tuned pipes for dirt bikes.
    Build a female mold, weld a pipe fitting to one end of your tube and cap the other, apply pressure with pressure washer, tube expands to fit mold. Some videos on youtube...
    673
    Quote Originally Posted by keebler303 View Post
    Yeah, that's pretty cool... who would have thought that would work?
  1. how to make arch cylinder
    By mwelch in forum Solidworks
    Last Post: 11-25-2014, 06:40 PM
  2. Metal laser cutting machine is easier to achieve diversification sheet metal
    By mornlaser2014 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 06-16-2014, 07:46 AM
  3. Replies: 6
    Last Post: 10-05-2013, 03:40 AM
  4. How can I Make a Drawn Slot in Sheet Metal
    By barnon in forum Uncategorised MetalWorking Machines
    Last Post: 01-20-2012, 10:16 PM
